2001 Chevy Malibu power outlet
73,000 MILES • 4 CYL • FWD • AUTOMATIC
LONSOM1
  • 6 POSTS
I have lost power to the power outlets and cannot find a blown fuse. Where is the fuse located and which kind is it?
Thank you
Jan 1, 2008 at 9:20 PM
2CARPRO JACK
  • 11,533 POSTS
Look in the underhood power center. Looking for the fuse labeled "aux powewr/cigar" 20 amp
Jan 2, 2008 at 7:31 AM
LONSOM1
  • 6 POSTS
I looked in both the power center under the hood and the fuse box in the passenger side and there are no blown fuses nor is there one labeled (Power-cigar)
Thank you for trying to help
Jan 2, 2008 at 6:44 PM
2CARPRO JACK
  • 11,533 POSTS
According to my wiring diagram that is the one.What is ht eexact production date of your car. Look on sticker on drivers door near the latch. Did you use a test light to verify there is no power?
Jan 2, 2008 at 11:28 PM
LONSOM1
  • 6 POSTS
My wife has the car so i cant look at the production date however i did use the test light on the fuse and it is ok thats what is puzzeling me plus the fact there is nothing labeled either Axu or cigar. How this whole thing started was i was having trouble with my cell phone charger not getting power so i was using the test light on the power outlet itself and accdently shorted it out. I would think it would just have blown a fuse but i cant find one for it. I will probably just take it into the shop.
Thank you so much for your help
Jan 3, 2008 at 12:06 AM
LONSOM1
  • 6 POSTS
I see it says 2001 that is a mistake the car is a 2005
Jan 3, 2008 at 12:09 AM
2CARPRO JACK
  • 11,533 POSTS
Then there is a fuse block in the trunk. Fuse #20 is for the aux power
Jan 3, 2008 at 3:23 AM
LONSOM1
  • 6 POSTS
I knew there was a box in the trunk but had no idea it was a fusebox. It was excatcly where you said it was and was blown. Thanks again!
Jan 3, 2008 at 8:56 AM
2CARPRO JACK
  • 11,533 POSTS
No problem
Jan 3, 2008 at 11:21 PM
LONSOM1
  • 6 POSTS
The site wont let me give you points for some reason it says i dont have any points to give. I just want you to know you did a great job. Thank you
Jan 4, 2008 at 3:54 AM
2CARPRO JACK
  • 11,533 POSTS
Thank you
Jan 4, 2008 at 4:19 AM
