Hi i have a check engine light on,hook up to sanner cly.4 misfire po304.I check for spark(ok)and check for compresstion(125lbs.)I can not check for injectors pluse because it is under pltam.Could it be a bad moduel?or injector?what do i from here?
PS i cleared the code and it did not come back on intill the motor was hot then it came back on #4 cly. misfire!How about a bad coil pack?Help
Mar 9, 2010 at 7:58 AM
