2001 Chevy Malibu P0446 code - check engine light on
38,000 MILES • 6 CYL • FWD • AUTOMATIC
SWEETGUYBL
I have replaced vent valve solenoid, evap cannister, and still get the P0446 fault code. What should I do next?
Sep 14, 2010 at 1:46 PM
MADMIKE1735
  • 951 POSTS
have you smoked the system???? without a snap-modis, and a smoke machine, its almost impossible to figure out faulty evap components.
Sep 14, 2010 at 1:47 PM
SWEETGUYBL
Not exactly sure what smoking the system means and what is a snap-modis?
Sep 15, 2010 at 2:04 PM
MADMIKE1735
  • 951 POSTS
when you smoke the system, there is a tool used to fill the evap system with smoke in order to find a leak.... the Snap On modis is a very expensive diagnostic tool that can be used to activate, or deactivate system components...
Sep 16, 2010 at 4:07 AM
SWEETGUYBL
[quote:f46e65e528="madmike1735"]when you smoke the system, there is a tool used to fill the evap system with smoke in order to find a leak.... the Snap On modis is a very expensive diagnostic tool that can be used to activate, or deactivate system components...[/quote:f46e65e528]
Thank you for your fast excellant answers. This is what I need to do now and I am sure I will be back to this site as it has proved to me to be very valuable.
Sep 16, 2010 at 12:17 PM
