If it creamy, coolant is getting into the oil. This could be caused by a bad intake gasket or head gasket. To determine which is the problem, I recommend doing a compression test. Here is a how to:
https://www.2carpros.com/dia/how_to_check_compression.htm
If you have low compression in one or more cylenders, chances are the head gasket is bad. If they are all good, chance are the intake is the problem.
Let me know what you find.
SPONSORED LINKS
Monday, September 7th, 2009 AT 12:22 AM
