2001 Chevy Malibu ENGINE LIGHT
103,000 MILES • 6 CYL • FWD • AUTOMATIC
1262DOG
FOR OVER A YEAR HAVE BEEN FIGHTING WITH ENGINE LIGHT COMING ON AFTER EVERY REPAIR THAT CODES SAY,REPLACE EGR VALVE ,O2 SENSORS TWICE,CONVERTER.LIGHT STILL KEEPS COMING AFTER A COUPLE OF MONTHS AFTER REPAIR.LIGHT CAME ON AGAIN WITH CODE SAYING
CAT BAD READING,ANY ANSWERS FOR IT.PLEASE
ANY IDEAS.
Mar 2, 2010 at 7:52 AM
MERLIN2021
  • 17,250 POSTS
if you can post the actual codes, it could help, GM had a PCM reflash to correct certain EGR code...
Mar 2, 2010 at 7:58 AM
1262DOG
THE CODE WAS PO420
Mar 3, 2010 at 5:52 AM
MERLIN2021
  • 17,250 POSTS
OK P0420 is not and EGR code, it's for catalyst efficiency! And either the cat is bad, or the O2 sensor after the cat is switching too much, a scantool that reads live sensor data will show a bad downstream O2 as a graph with a lot of high and low peaks, a good one has an almost flat line after the cat and high peaks on the sensor before the cat.
https://images.2carpros.com/forum/automotive_pictures/62217_P0430a_3.jpg
https://images.2carpros.com/forum/automotive_pictures/62217_P0430b_High_3.jpg
Top picture shows a bad sensor, bottom picture shows a good sensor. Or bad cat!
Mar 5, 2010 at 7:25 AM
