2001 Chevy Malibu Cylinder Head and Block
TOMSHANTY
  • 34 POSTS
Engine Mechanical problem
2001 Chevy Malibu 6 cyl Front Wheel Drive Automatic
I am currently in the process of replacing my cylinder head gaskets. In the Haynes manual, it says, "The mating surfaces of each cylinder head and block must be perfectly clean when the head is installed."
I've had the heads machined but not the engine block. So as far as the block is concerned, I was wondering how clean is "perfectly clean"? Should it look brand new? Because I don't think that's possible unless I take the entire engine out and have the block machined.
I have cleaned it thoroughly. There are no signs of oil or gasket residue. It is obvious however that is has not been machined. I will insert a picture if that helps.[img:8e1e422bda]http://www.2carpros.com/forum/automotive_pictures/377707_30f0387bd7f8__1271857096000_1.jpg[/img:8e1e422bda]
So basically all I want to know should okay as long as the block has no signs of residue or debris? Or does it have to look shiny new?
Thanks,
Thomas
Apr 26, 2010 at 8:35 AM
DOCFIXIT
  • 18,828 POSTS
Thomas
Looks great you did it right free of gasket material ,oil ect
Your good to go
Apr 26, 2010 at 8:40 AM
