2001 Chevy Malibu car tunrs over but won't start
FELECIA
Engine problem
2001 Chevy Malibu V6 Front Wheel Drive Automatic 91000 miles
my cars turns over but won't start i replace fuel pump, wires and plugs i check my map sensors it was good and i replace the igition control module
Dec 4, 2007 at 1:04 AM
BMRFIXIT
  • 19,053 POSTS
[quote:46ad4e7fe9="felecia"]Engine problem
my cars turns over but won't start i replace fuel pump, wires and plugs i check my map sensors it was good and i replace the igition control module[/quote:46ad4e7fe9]
You did all this, well.
But can you tell if you have spark or fuel
Pressures .
you need to check then replace not the other way around
I’d say pull one of the spark plug wires try to crank and watch if you have spark if so
Move on the fuel pressure
If not check or replace crank position sensor
Good luck let me know what missing and I will help you
Good luck
Dec 6, 2007 at 11:16 AM
