replaced oil press switch
80,000 MILES • 6 CYL • 2WD • AUTOMATIC
BLUEFOX
Had wrong speedo in car-changed and reprogrammed computer-now 1189 comes up and can't find out why-replaced oil press switch-before speedo and computer change-it had misfire codes-could it have something to do with radio module? Should I take to another shop or replace computers? 1189 oil senser I believe. Need to get lite off to smog.
Feb 9, 2010 at 6:27 AM
SERVICE WRITER
  • 9,123 POSTS
I think there was a software glitch on this code.
Did you have the software upgraded with the latest and greatest?
All of this stuff was done at a shop trying to resolve this code?
Feb 9, 2010 at 11:04 AM
BLUEFOX
Ultimate Motors Inc. did the work-now 1189 code is gone and U1000 Class 2 serial communication failure-no counication with ABS or SRS modules-airbag, ABS, and check engine light on now-repair shop gave up-2010 updates and management system-go to chevy and maybe reset modules or tradein????
Feb 10, 2010 at 2:58 AM
SERVICE WRITER
  • 9,123 POSTS
Okay so there is a communication error. If you like the car this is repairable. The modules need to communicate with each other.
Feb 10, 2010 at 3:11 AM
EDBODI1
I am needing to know the location of the oil sending unit as my Mom's is going bad.
May 23, 2020 at 9:29 AM (Merged)
  • 75,988 POSTS
https://images.2carpros.com/forum/automotive_pictures/12900_ngine_oil_pressure_sensor_1.jpg
