2001 Chevy Malibu
LJS MOMMY
  • 2001 CHEVROLET MALIBU
2001 Chevy Malibu
i shattered a window on accident its the driver side window and I need to figure out how to fix it. I cant afford to go to a repair shop. And I dont knwo anyoen that knows how to do it. So if someone could give me soem instructions that would be awesome
gratefully
ljsmommy
Friday, May 22nd, 2009 AT 10:47 AM
MIKE H R
  • 3,094 POSTS
The drivers inside door panel has to be take off, there are plenty of sharp metal edges so be careful. The window is secured to the window track on the bottom. There are two nuts that hold the window on the track. These nuts have rubber insolators so the metal will not break the window. Put window half way up to gain access to other side. Loosen the nuts and remove the nuts and rubber grommets. Clean out any glass around area. To install reverse proceedure
Friday, May 29th, 2009 AT 10:45 AM
