2000 Chevy Malibu want start
89,000 MILES • 6 CYL • 2WD • AUTOMATIC
CHAUNROWLAND
the car cranks but wont start and when I turn the key I can hear the fuel pump turn on but it still wont start. Even if the fuel pump turns could it still be bad
Dec 15, 2007 at 2:46 PM
BMRFIXIT
  • 19,053 POSTS
[quote:4fd25a664b="chaunrowland"]Engine problem
2000 Chevy Malibu 6 cyl Two Wheel Drive Automatic 89000 miles
the car cranks but wont start and when I turn the key I can hear the fuel pump turn on but it still wont start. Even if the fuel pump turns could it still be bad[/quote:4fd25a664b]
check if you have spark
Dec 16, 2007 at 7:12 AM
STALLJH
GM vehicles are notorious for having ignition anti-theft system problems. Is your anti-theft light blinking? Even if not, here's an easy method to check. Put in key and turn to ACC, then leave car alone for over 10 minutes. During this time, the computer will relearn the chip in your key. After 12 minutes, turn ignition to off and then try to start. If it starts right up, then your problem is the anti-theft system. It may happen again, but then you just have to wait with the key in ACC and do it over again. Check that out.
Dec 17, 2007 at 2:33 PM
