2000 Chevy Malibu Tugging
15,900 MILES • 6 CYL • 2WD • AUTOMATIC
EETIRADO
I feel a tug (like a fish pulling on a fish line) when I accelerate. It's worse if I'm going up hill. I noticed an improvement after a tune up and a transmission overhaul but the problem persists.
Aug 15, 2010 at 3:42 PM
  • 75,988 POSTS
Lack of acceleration,chugging,hesitating,bogging,misfiring etc. could be caused by one of the following below:
Start here inspect test all the items below-and get back with some results.
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it.
Aug 15, 2010 at 4:22 PM
