spark plug gap?
MICHAEL DURBIN
Six cylinder front wheel drive automatic. What do I have to gap the spark plugs at when I put in new ones?
May 7, 2010 at 4:09 AM
BLUELIGHTNIN6
  • 16,542 POSTS
.060 (In thousandths of an inch). Here is a guide that will help you install them as well
https://www.2carpros.com/articles/how-to-change-spark-plugs
May 7, 2010 at 4:11 AM
TAWNYS
my 2000 chevy malibu will have rpm at 2 or 3 in park. And while driving it will be at 3rpm without ever touching the gas. It is the craziest thing..... I can go all the way to work without ever touching the gas petal. What wrong? I've had the fuel system cleaned out new spark plugs and spark plug wires. I still have the same problem.
Jan 23, 2019 at 11:08 AM (Merged)
DOCFIXIT
  • 18,828 POSTS
Suspect faulty IAC see diagram
TAWNYS
do you have an estimate on cost? or time it takes to replace?
DOCFIXIT
  • 18,828 POSTS
Part @$80 time 1 hour
TAWNYS
last question.... When I go to start the car (no matter if it's been sitting for a while or not) it will act almost like its flooded.... but after a few trys it will start. Now it doesnt do this all the time but will do this probably 3 out of 5 times.... could this also be related to a faulty IAC?
DOCFIXIT
  • 18,828 POSTS
yes
CHUCK1990
where are the spark plugs located on a 1997 chevy malibu
HMAC300
  • 48,601 POSTS
there are 3 in each head. the first three i'm sure you can see at the end of the plug wires. the other three are similarly placed and can be reached with a fle head rachet and plug socket. sometimes the top dogleg mounts haveto be taken off and the car put in neutral and the engie rocked forward to remove the plugs. Make sure to do this on a cool engine as you can strip the head removing them and put anti-seize on the new plug threads for ease of removal next time.
SATURNTECH9
  • 30,869 POSTS
There right below the valve cover's i posted a diagram follow the spark plug wire's from the coil's to the spark plug's.
RAY CHITWOOD
My check engine light is on and I need to know where spark plug # 2 is
BLUELIGHTNIN6
  • 16,542 POSTS
Firing Order .................... 1-2-3-4-5-6
Here is the cylinder numbers for the 3.1L
See attachment below
JOE 41979
Electrical problem
1997 Chevy Malibu 6 cyl Front Wheel Drive Automatic
need to know the spark plug wiring diagram
BLUELIGHTNIN6
  • 16,542 POSTS
https://images.2carpros.com/forum/automotive_pictures/261618_Graphic_381.jpg
DAWNLEE
Engine Mechanical problem
1999 Chevy Malibu 6 cyl Automatic
My Motor is Making like a knocking nose and It has lose of power when you try to take off after you get the car to like 45/50 it has no trouble going. Please help me We Did the oil and The spark Plugs what do you think it can be please Help me out
Thank you,
Dawn
BILLYMAC
  • 2,204 POSTS
did you change spark plug wires?
DAWNLEE
Yes we did!
BILLYMAC
  • 2,204 POSTS
you have a cylinder missfire you have to find out which cylinder is causing the prob. with engine running remove a spark plug wire one at a time use insulated pliers for this. each time you remove a wire the eng should idle down. if you get to one that you can remove the wire and the rpms do not drop this is your problem cylinder.
please feel free to reply if you need more help
DAWNLEE
Is it possible it can be a fuel injector???
BILLYMAC
  • 2,204 POSTS
Hi Yes it is possible that it is an injector. you need to isolate it to the cyl that has the prob then it could be a injector wire plug.or mechanical
