2000 Chevy Malibu P1410 EGR Valve Position Sensor Circuit M
82,000 MILES • 6 CYL • 2WD • AUTOMATIC
ROBWALLEP
  • 5 POSTS
I replaced the EGR valve to fix the problem, but the problem still exists with the engin light and the same code is still the same. Please let me know what the next step will be to fix this issue.
Feb 25, 2008 at 1:13 PM
BLACKOP555
  • 10,386 POSTS
did the new egr come with the EVP? if not try replacing that or the DPFE sensor.
Feb 25, 2008 at 11:55 PM
ROBWALLEP
  • 5 POSTS
I checked for a DPFE sensor for that model vehical and they said for that year they did not put one in thehy only placed it on a 2004 model
Feb 26, 2008 at 11:44 AM
ROBWALLEP
  • 5 POSTS
Quick question what is a EPV
Feb 26, 2008 at 11:49 AM
ROBWALLEP
  • 5 POSTS
I mean EVP sorry
Feb 26, 2008 at 11:50 AM
DENNYP
  • 1,824 POSTS
There is no p1410 code for a 2000 malibu. Can you double check the code again and post it for me. It will help us with a good starting point.
Feb 26, 2008 at 12:03 PM
ROBWALLEP
  • 5 POSTS
The wording for the error was EGR valve circuit malfunction. I was not sure on the code number
Feb 26, 2008 at 12:46 PM
DENNYP
  • 1,824 POSTS
I will need the proper code number since there are several different codes relating to EGR control circuits.
Feb 26, 2008 at 10:58 PM
MIKLO2008
  • 6 POSTS
THE PROPER CODE IS P0405. I HAVE THE SAME PROBLEM.
Aug 16, 2008 at 2:34 PM
BLACKOP555
  • 10,386 POSTS
if there is no dpfe, then you must have a evp *egr valve position sensor*
that would be the only other component to cause this to act up.
either that or a bad wiring harness.
Aug 17, 2008 at 2:28 AM
