2000 Chevy Malibu Installing Connectors
68,520 MILES • 6 CYL • FWD • AUTOMATIC
VTCAROL50
  • 22 POSTS
Which is the best way to install a connector. I need to replace the intake air temperature sensor but the connector wire is broken.
Their is a pigtail connection kit which says to heat shrink after you have made the connections. What do I need to heat shrink this connection.
Jul 3, 2010 at 2:40 AM
HMAC300
  • 48,601 POSTS
a lighter works great on heat shrink tubing. you can also use a torch, but that gets to be dangerous and intense. You might try a hair dryer as well.....or a big match..... be careful if you are around fuel though...
Jul 7, 2010 at 10:44 AM
