2000 Chevy Malibu fuel leak
75,000 MILES • 6 CYL • FWD • AUTOMATIC
1977FXE
I replaced my upper and lower intake gaskets, i disconnected the fuel rail connections in order to replace the gaskets. I reassembled the entire manifold and re attached the fuel lines. the front rail (regulator) is held in place with a single torx screw, it went back easily. The rear rail was fitted with a new o-ring and it leaked the moment pressure was put on it. I removed the the rear connection and found that the o-ring wasdamaged, I bought a new o-ring and installed it with care. Again it leaked and had been damaged. the interior seating area is nick-free and smooth. what am I doing wrong?
Sep 2, 2009 at 7:31 AM
  • 110,248 POSTS
Have you tried to lubericate the new o-ring before replacing it?
Sep 6, 2009 at 4:06 PM
