2000 Chevy Malibu Engine Surges
FLIP
Engine Performance problem
2000 Chevy Malibu 6 cyl Two Wheel Drive Automatic
Whenever I exceed 60 mph, my engine begins to surge and eventually shut itself off. It had check engine light on and I replaced the Knock Sensor and EGR valve. I too changed the fuel filter yet the problem persists. Could this be a transmission problem? Any Advice?
Oct 27, 2009 at 8:36 AM
RHALL77
  • 3,361 POSTS
is it setting a check engine light? if so can you get me the code. does the vehicle start up right away afterwards?
Oct 28, 2009 at 10:07 AM
FLIP
Actually, I found the issue. Seems like a wire somehow melted that connects to the distributor. Not sure of the name or where I can go buy it.
Oct 30, 2009 at 4:51 AM
