2000 Chevy Malibu DIFFICULT DIAGNOSIS
65,000 MILES • 6 CYL • FWD • AUTOMATIC
DAVID GARRISON
MY MALIBU WOULD CRANK BUT NOT IGNITE, EVEN WITH A HOT SHOT. THE ONLY PREVIOUS PROBLEM WAS THAT OCCASIONALLY THE ELECTRIC WINDOWS, A/C, AUTOMATIC LIGHTS, SPEEDOMETER NEEDLE AND FUEL GAUGE WOULD NOT WORK FOR ABOUT TWO MINUTES UPON STARTING THE CAR. I HAD THE CAR TOWED ON A TRUCK TO A GARAGE AFTER NOT STARTING FOR A FEW WEEKS AND UPON ARRIVAL AT THE REPAIR SHOP, IT MYSTERIOUSLY STARTED!! ELECTRICAL DIAGNOSIS REVEALED NO PROBLEMS. MECHANIC THOUGHT STARTING PROBLEM COULD BE DUE TO FAULTY IGNITION SWITCH AND/OR AN ANTIFREEZE LEAK, BUT THERE IS LITTLE OR NO LEAK OF THIS KIND. REPAIR TECHNICIANS NOW WANT TO RUN A TEST ON THE FUEL PUMP. THE CAR HAS BEEN SITTING IN THE REPAIR SHOP FOR ONE WEEK, AND WE FEEL IT IS BECOMING AN EXPENSIVE GUESSING GAME, AS NOW THEY ARE ADVISING AGAINST IGNITION SWICH REPAIR. IT SEEMS TO ME, WITH THE CAR'S PREVIOUS HISTORY, IT IS PROBABLY ELECTRICAL MALFUNCTION. I AM CONSIDERING MOVING THE CAR TO ANOTHER REPAIR SHOP, BUT DO NOT WANT TO GO THROUGH THE ABOVE SCENARIO A SECOND TIME. THE CAR CONTINUES TO START WITHOUT PROBLEMS AT THE SHOP.
Dec 2, 2008 at 4:55 PM
BMRFIXIT
  • 19,053 POSTS
When was the car shipped to the repair shop did you leave key in the ignition
and if so I would suspect ignition switch
do u recall seeing security light on and or flashing when it didn’t start for you and if so its the ignition cylinder and switch
if none of the above have to drive the car and try to duplicate the problem
fuel pump test may reveal a weak pump
antifreeze leak will not stop the car from starting
most common place for it to leak is the intake manifold gasket
good luck
Dec 2, 2008 at 10:32 PM
