2000 Chevy Malibu Car won't start after lower manifold repl
115,000 MILES • 6 CYL • FWD • AUTOMATIC
2000MALIBU
  • 5 POSTS
I just replaced the lower intake manifold on my 2000 Chevy Malibu with the 3.1 V6. When I was trying to torque the pushrods down my torque wrench bit it and I had to just go by a guess. My main question is, what is the torque setting for the rocker arms and do these rocker arms need to be adjusted or no? I'm thinking the valves may be too tight and not allowing it to start.
I've done a compression check and I get between 145-160 on all cylinders. The motor will turn over easily and if I let it cycle over about 5 times it will kind of make a backfire sound, but sounds more like it is coming from the intake rather than exhaust. Any tips are greatly appreciated.
Jason
Jan 6, 2008 at 10:37 PM
BMRFIXIT
  • 19,053 POSTS
[quote:150ee1af20="2000malibu"]Engine problem
2000 Chevy Malibu 6 cyl Front Wheel Drive Automatic 115000 miles
Jason[/quote:150ee1af20]
start by making sure you have the right firing order \
also did you remember that you have small and long push rods and you installed them where they should go
let me know
if you need the firing order
good luck
Jan 7, 2008 at 11:31 AM
2000MALIBU
  • 5 POSTS
hey, thanks for the response.
I did put the pushrods back in correctly, but I had misread the manual for the torquing. I had torqued over 100 FT/lb rather than the 168 IN/lb.
So, I've taken out the pushrods and nothing is bent, about to replace everything and retighten to 14 FT/lb which is 168 IN/lb.
I'll let you know if it works!
Jan 7, 2008 at 11:39 AM
BMRFIXIT
  • 19,053 POSTS
[quote:b1f26f098b="2000malibu"]hey, thanks for the response.
I'll let you know if it works![/quote:b1f26f098b]
lucky lucky you didn’t break them bolts
yap let me know
also firing order check it
and if all ok try to hold gas pedal 1/3 the way down and try to start
it will run rough for the 1st few minutes but it will adjust after
Jan 7, 2008 at 11:59 AM
2000MALIBU
  • 5 POSTS
well, got the rocker arms re-torqued correctly and everything put back together and she still won't start. Firing order is correct but it is pouring rain and the coil pack contacts and spark plug wire boots did get a little wet...maybe this is part of my reason now.
Jan 7, 2008 at 1:43 PM
BMRFIXIT
  • 19,053 POSTS
[quote:b684ad99d3="2000malibu"]well, got the rocker arms re-torqued correctly and everything put back together and she still won't start. Firing order is correct but it is pouring rain and the coil pack contacts and spark plug wire boots did get a little wet...maybe this is part of my reason now.[/quote:b684ad99d3]
this is what i was thimking
you drained the oil out of the lifters and you need to crank it bit longer to builds up pressure
for it to fire up
also dry wires always help
Jan 8, 2008 at 10:08 PM
2000MALIBU
  • 5 POSTS
well, she finally started! There was just so much moisture in the cylinders and on the ignition components from all the rain and snow we've gotten here in Michigan over the past week.
Now it's just making a loud heavy ticking noise which I'm assuming is probably just the lifters pumping back up?
Thanks!
Jason
Jan 9, 2008 at 3:16 AM
BMRFIXIT
  • 19,053 POSTS
[quote:894c5474a5="2000malibu"]well, she finally started! There was just so much moisture in the cylinders and on the ignition components from all the rain and snow we've gotten here in Michigan over the past week.
Thanks!
Jason[/quote:894c5474a5]
Great !!
let it idle for a few
don’t try to give it gas
after it will smooth out
by the way you changed the oil and filter I hope
if not do it
Jan 9, 2008 at 5:44 AM
2000MALIBU
  • 5 POSTS
yup, changed the oil right after she started running again and the filter as well.
Thanks!
Jan 9, 2008 at 3:32 PM
X33
  • 5 POSTS
hi guys i have the same issue about a week ago i have replaced the lower cylinder head gasket after installing every thing at the same place where it came but the engine crank wont start, i had drained the oil before one week to installing the new head gasket .... will you help me plz i am stuck :( :'(........
Jan 16, 2013 at 8:35 AM
X33
  • 5 POSTS
3.1 V6 malibu 2000 :(
Jan 16, 2013 at 8:36 AM
X33
  • 5 POSTS
As it seems all mentioned posts are 5 years old & now no one is here to help me :'(....
Jan 17, 2013 at 12:11 AM
