2000 Chevy Malibu brake failure
DOROTHY25
Brakes problem
2000 Chevy Malibu 6 cyl Front Wheel Drive Automatic
I have had the master cylinder,brake booster and rear brake cylinders replaced. The master cylinder was bench bled and the wheels were bled and I still don't have any brakes. Brake pads and shoes are good. After bleeding the brakes they will work about 3 times and on the fourth time they go to the floor,then you can pump the brakes until they get hard and the same thing happens they go to the floor. Any help would be appreciated
Nov 5, 2008 at 11:08 AM
RHALL77
  • 3,361 POSTS
are the rear brakes adjusted properly
Nov 10, 2008 at 8:03 AM
