2000 Chevy Malibu
CSTORY
  • 2000 CHEVROLET MALIBU
Engine Cooling problem
2000 Chevy Malibu 6 cyl Automatic
my car started getting water in the oil after I changed the water pump and thermostat could it just be a bad seal in the water pump
Saturday, January 30th, 2010 AT 10:40 AM
ERNEST CLARK
  • 1,730 POSTS
The water pump/gasket on your V6 doesn't come into contact with any oil passages. Nor does your thermostat/housing.
On this particular motor, when coolant gets into the oil, it's usually via the intake gasket, though a blown head gasket is a possibility.
The best thing to do is rent a cooling system pressure tester and check it out. Also, a compression checker will tell you if you have a blown head gasket.
If I've helped you, please take the time to vote for me as my reputation pays my bills. Thanx, Ernest.
Wednesday, July 31st, 2019 AT 5:04 PM
