1999 Chevy Malibu Trouble code p0301
1999 CHEVROLET MALIBU
127,100 MILES • 6 CYL • FWD • AUTOMATIC
JAYS TOYS
I have a 99 malibu trouble code p0301 Just need some advice. I have replaced the plugs and wires, coil pack, module, and the compression is good. Any idea what the problem could be? Any help would be greatly appressiated.
Aug 3, 2008 at 1:32 PM
Test the injector on that cylinder-Misfires can be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel.
Aug 3, 2008 at 1:40 PM
