1999 Chevy Malibu No spark after water pump replacement
141,000 MILES • 4 CYL • FWD • AUTOMATIC
1970W30
1999 Chevy Malibu 2.4L. Ran fine needed a water pump, changed the water pump but did not replace the timing chain. The water pump is driven off of the timing chain. I did not move the cams or crank during the install of the water pump. Prior to the repair I disconnected the battery, negative side. I unplugged the O2 sensors and the ignition pack. Everything went back together as is should. When I went to start the car I could hear the fuel pump start, the engine would crank but it does not appear to be getting any spark. Any help would be appreciated.
Mar 19, 2010 at 2:50 PM
BMRFIXIT
  • 19,053 POSTS
Should run a code test on it
check if security light on and or blinking
recheck the connectors
Mar 19, 2010 at 9:14 PM
