1999 Chevy Malibu misfire in #1 cylinder
147,000 MILES • 6 CYL • FWD • AUTOMATIC
TAYLOR43
I recently replaced the head gaskets on a 99 chevy malibu engine ran rough pulled codes using scanner came back with a p0301 cylinder#1 misfire I have replace spark plugs and wires any other suggestions
Mar 14, 2008 at 11:07 AM
BLACKOP555
  • 10,386 POSTS
are you getting bright blue spark on that cylinder?
Mar 14, 2008 at 11:12 AM
MERLIN2021
  • 17,250 POSTS
This can be anything from improper lifter installation to a warped head, check compression in the cylinder, it's recommended to soak the lifters for several hours prior to installaltion in oil...? Can be a bad valve, vale spring lifter, head or gasket...
Mar 14, 2008 at 11:19 AM
SERVICE WRITER
  • 9,123 POSTS
Swap two of the fuel injectors to see if the miss moves. # injector and what ever it most convenient. Orings were replaced correct?
Mar 14, 2008 at 12:39 PM
