1999 Chevy Malibu Inner CV Joint or Differential
130,000 MILES • 6 CYL • FWD • AUTOMATIC
TRBOYCE
I keep on hearing this whirling or grinding noise. It gets louder when I go faster. We have changed the cv joint and the bearings. There is no dirt in the breaks. I have narrowed the noise to the inner cv joint area. Someone told me I might be low on fluid in the differential area. Not sure what to think??
Feb 13, 2009 at 10:44 AM
BILLYMAC
  • 2,204 POSTS
hi well there is a bearing right inside the diff assy this bearing commonly goes bad. the diff on this vehicle is automatically lubricated by the trans itself.the prob in the diff is actually conciddered in the automotive industry as a trans prob.good luck billymac
Feb 13, 2009 at 11:11 AM
CRZYDRVR
  • 432 POSTS
Another thing that would be helpful to check out is a wheel bearing going bad. Commonly you will hear a "growling" noise with that too.
Feb 17, 2009 at 11:45 AM
