1999 Chevy Malibu ignition wont turn off
1999 CHEVROLET MALIBU
117,690 MILES • 6 CYL • 4WD • AUTOMATIC
LUCILU34
My ignition will not turn off, it stays on acc and the airbag light is on, and my gas says it is low, when i have a full tank
Mar 27, 2009 at 9:23 AM
ABDAVISJR
I'm not expert but I too had this problem with my 98 Malibu. When I turn my car of I have to push the shifter (where it says drive, reverse,etc.) forward or backwards a little, try that you should hear a click then turn you're key to the off position. My mechanic said that my steering column was worn and had a slight crack in it.
Apr 10, 2009 at 5:24 PM
