1999 Chevy Malibu High beams work but low beam just on driv
123,000 MILES • 6 CYL • FWD • AUTOMATIC
MARYGRACEB
My low beams on my driver side are not working, not even the running lights or the fog lights on the driver side. I have tried changing the light bulbs and changing the wire to the lightbulb. Nothing has worked and I need my lights to work. What can I do to fix it without costing me a ton of money? The lights on the passenger side work perfectly.
Aug 28, 2008 at 11:07 PM
DOCFIXIT
  • 18,828 POSTS
Maybe a bad ground connection. Look at the headlamp plug should be a black wire follow if you can to see if it connects to car body. If you can't get a jumper wire and jump to ground.
Let me know
Aug 29, 2008 at 6:34 AM
