1999 Chevy Malibu head gaskets
187,000 MILES • 4 CYL • FWD • AUTOMATIC
JENESAPP
i have water boiling back into my resivior jug but my temp is fine does this mean i have a blown headgasket
Oct 21, 2008 at 10:35 AM
  • 31,937 POSTS
Hi there,
Your mechanic can test for a head gasket problem easily, when you say the water is "boiling"back is it steaming? as you may have a second problem with a faulty temp sender as it should indicate an overheating problem, but only if the sensor is still covered with water, check the coolant level and get a head check done.
Mark (mhpautos)
Oct 21, 2008 at 11:11 AM
