1999 Chevy Malibu fuel injectors circuit
1999 CHEVROLET MALIBU
BILBO37
  • 5 POSTS
Engine Mechanical problem
1999 Chevy Malibu 4 cyl Front Wheel Drive Automatic
I put a tester on my 1999 malibu and it said that an injector circuit was staying open. I traced it down to the first injector towards the drivers side.
Does this mean that I need to replace the computer module in the vehicle? Or is there something else that I should look for?
Jan 22, 2009 at 7:16 AM
DOCFIXIT
  • 18,828 POSTS
What code was it in a P0xxx format
Jan 22, 2009 at 7:23 AM
BILBO37
  • 5 POSTS
I had borrowed the tester from my dad. I don't remember the error number.
Jan 22, 2009 at 7:27 AM
DOCFIXIT
  • 18,828 POSTS
Got an Ohm meter if yes unplug suspect injector Ohm across terms. If no reading then injector coil winding is open replace.
Jan 22, 2009 at 8:09 AM
BILBO37
  • 5 POSTS
I have switched injectors between cylinders. same thing is happening on the same cylinder.
Jan 22, 2009 at 9:03 AM
BILBO37
  • 5 POSTS
We used a OBD2 tester. The error code was P0201 Injector circuit open cylinder 1. Any help would be appreciated. Thanks for taking the time...
Jan 22, 2009 at 10:36 AM
DOCFIXIT
  • 18,828 POSTS
A P0201 indicates problem in wiring from PCM to injector or the PCM itself. Problem is you need a scan tool to repair.and of course training. So it looks like a trip to shop is in your future.
Jan 23, 2009 at 2:04 AM
BILBO37
  • 5 POSTS
Ok. Thanks for your help on this matter.
Jan 23, 2009 at 2:10 AM
