1999 Chevy Malibu Cylinder 3 misfire detected
BKSFLYESTPAPI333
  • 1999 CHEVROLET MALIBU
  • 6 CYL
  • FWD
  • 70,000 MILES
The code my check engine light gave me was indicating that cylinder 3 is misfiring. The compression of the third cylinder read at 65 psi. What needs to be done to repair this issue and is it worth fixing?
Tuesday, January 1st, 2008 AT 7:54 AM
BLACKOP555
  • 10,371 POSTS
What are the other ones? Is it over 25% less then the highest. If so then you need the cylinder rehoned. But first I would have the lifters and valve springs changed on it and the pushrods, and on the cylinder I would put new piston rings on it and hone out the cylinder, if this dontwork its up to you to hvae your cylinders rebored or put in a new engine, I would go wiht new engine.
Tuesday, January 1st, 2008 AT 12:10 PM
BKSFLYESTPAPI333
  • 25 POSTS
Thats gonna suck because I just bought this engine like 2 months ago but it was used.
Tuesday, January 1st, 2008 AT 12:16 PM
