my 1999 malibu starts and runs for a few minutes, then it starts cutting out and dies. it will restart. it had a fault code p0108 map voltage high. I have since replaced map sensor and fuel pump. I checked the continuity of the three wires from the map sensor to the pcm and they checked fine, so I replaced the pcm. now it will not start and the alarm light is on. help!
Jul 11, 2009 at 8:24 AM
