1999 Chevy Malibu
JWILL3448
  • 1999 CHEVROLET MALIBU
Tires and Wheels problem
1999 Chevy Malibu 6 cyl Two Wheel Drive Automatic
how do you change the front wheel bearing asssembly
Wednesday, March 24th, 2010 AT 11:06 AM
TOOOMANYTOYS
  • 513 POSTS
Raise vehicle remove wheel remove brake caliper assembly remove three bolts holding hub to spindle. Disconnect abs speed sensor remove axle nut. Then reverse process to install new hub. You need 19mm socket 21 mm socket 13mm socket and 36 mm socket. A impact gun or large ratchet.
Wednesday, March 24th, 2010 AT 11:17 AM
