1999 Chevy Malibu
MSAN20221
  • 1999 CHEVROLET MALIBU
  • 6 CYL
  • FWD
  • 107,000 MILES
I'm not sure if its an electrical problem or not my tachometer will bounce up and down and the car will hesitate as this is happening, sometimes the tachometer doesn't even work and the car runs smooth. So far the mechanic has changed the cam sensor, the crank sensor, and the abs computer which he thought was shorting out the system, he also changed another computer I'm not sure what that was however the car is still not running right.
Wednesday, August 12th, 2009 AT 11:20 PM
BMRFIXIT
  • 19,053 POSTS
The Malfunction Indicator Lamp (MIL) is ON
This condition may also be the result of an incorrect installation of an aftermarket electronic device such as a remote starter or alarm system
Thursday, August 13th, 2009 AT 6:29 AM
MSAN20221
I'm not sure I know what the Malfunction Indicator Light is however on the Malibu if there is a problemlike low oil or something like that the car will ding ding ding to let you know something is wrong and something will light up in this case it does not always happen but theding will sound and thewre are several things lit up abs airbag and check engine thanks in advance for any help.
Thursday, August 13th, 2009 AT 4:05 PM
BMRFIXIT
  • 19,053 POSTS
Have to have it checked for codes you can start by checking PCM codes any OBDII reader can access the codes stored in the PCM internal memory
codes will help in pin pointing troubled area
Thursday, August 13th, 2009 AT 6:37 PM
