1999 Chevy Malibu
SNAKESKIN9
Electrical problem
1999 Chevy Malibu 6 cyl Front Wheel Drive 109000 miles
my 1999 malibu wont start fuel pump isnt coming on i checked relay it is fine fuel pump is fine if i put juice to the box that the relay goes into it will run
May 4, 2008 at 10:25 AM
RHALL77
  • 3,361 POSTS
you need to check and see if you have a theft code in the system
May 5, 2008 at 1:14 AM
SNAKESKIN9
[quote:a15665fd3b="rhall77"]you need to check and see if you have a theft code in the system[/quote:a15665fd3b]how do i check to see if there is a theft code
May 6, 2008 at 11:38 AM
RHALL77
  • 3,361 POSTS
you will need a scan tool that will read body control systems or you will have to take it to your local dealer.
May 7, 2008 at 12:09 AM
SNAKESKIN9
[quote:e861764045="rhall77"]you will need a scan tool that will read body control systems or you will have to take it to your local dealer.[/quote:e861764045]i have a scan tool not sure if it is the right one or how to find the theft code my tool is a actron cp9150
May 8, 2008 at 8:23 AM
