1998 Chevy Malibu ignition switch
SEVLEN
Electrical problem
1998 Chevy Malibu 6 cyl Two Wheel Drive Automatic
Do I have to replace the hole ignition carrier. And pull all of it out by disconnecting the wires or can you replace just the round switch where the key is put in. Like the ones that use a little pin you put in when the key is in also
Oct 17, 2010 at 7:03 AM
SATURNTECH9
  • 30,869 POSTS
Can you turn the key to different position's?
Oct 17, 2010 at 2:47 PM
