1998 Chevy Malibu ignition cylinder
134,000 MILES • 6 CYL • FWD • AUTOMATIC
GALASSO
I've recently replaced the ignition cylinder, due to worn pins, couldn't turn key easily. With the new cylinder in the engine cranks but dosen't turn over. I've also noticed the gas needle is not registring anything, even in accessory mode. The cylinder has (3) plastic plugs that clip into it. I'm sure the problem is there, but don't know how to go further?
Jul 28, 2008 at 6:17 AM
RHALL77
  • 3,361 POSTS
are you sure you have the lock cylinder lined upped correctly. does the key go in and out ok
Jul 28, 2008 at 2:21 PM
