1998 Chevy Malibu Help! - Cannot remove front, driver side
1998 CHEVROLET MALIBU
110,000 MILES • 6 CYL • FWD • AUTOMATIC
HOBGOBLIN
I've drilled out the 3 mounting holes on the power window motor housing, but the motor is literally stuck in place to the regulator. I'm not sure if it's been glued on, but no matter how hard I try to pry it off, it won't budge. Any suggestions as to how I can successfully remove the power window motor from the window regulator would be greatly appreciated!
Aug 20, 2008 at 5:43 PM
BMRFIXIT
  • 19,053 POSTS
Remove the glass 1st then u have bolts and rivets
to remove it out the door then the rivets
Aug 22, 2008 at 12:18 AM
