1998 Chevy Malibu Fuel Filter Removal
169,000 MILES • 6 CYL • FWD • AUTOMATIC
BKLORENZ
There is a black plastic ring around the tube end of the filter that is on the car. It is no longer intact, due to age and possible misuse. There is only one tab left on it, so is there still a way to remove the filter ? I have tried for an hour with no luck, but i have never run into this kind before.
Do i have to replace the pump assy. if i cant get it off ? or does the black plastic tube come off of it ?
Aug 19, 2008 at 2:02 PM
2CARPRO JACK
  • 11,533 POSTS
IS there small "windows" where you can see the plastic locks? if so try using a pick to push them in to release the lock. Some require a release tool to get off the filter, available at your local parts store
Aug 20, 2008 at 12:35 AM
BKLORENZ
I cant see anything except the black plastic part. It goes inside the fuel line. So i understand, if the black plastic part were intact, would i push it towards the filter to release the latch, or the opposite ? There is no room for the tools i have seen to fit.
Aug 20, 2008 at 2:35 PM
2CARPRO JACK
  • 11,533 POSTS
try pushing it into the fuel line to release it
Aug 21, 2008 at 12:42 AM
CJ15
So it is a couple months later and I had to fight the same problem. My 2001 Chevy Malibu fuel filter is difficult to remove. The connector is a little different than described above, but enough so that I thought to tell how I removed it. The only people who care are you who searched to find this.
The hose from the fuel pump ends at the fuel filter with a green plastic "quick disconnect." The quick did not work for me, so I finally figured out to a) open the green clip by flexing its retainer back a little and pulling the clip surface down toward the ground, and b) push the entire green plastic structure up and through the hose-end structure. On its way out the fuel filter could finally be extracted.
Finally, the newly purchased fuel filter's white clip had to be removed (it was slightly too wide) and the original green clip reused. I had to insert the green clip part way, stick in the fuel filter, then push the green clip structure all the way in.
Sep 20, 2008 at 7:56 AM
