The car will star but shuts off right away could it be the fuel pump or fuel pressure regulator.
Jun 6, 2008 at 8:28 AM
✓Experienced Mechanic
Check the fuel pressure with a fuel pressure tester to rule out the fuel pump with and w/o vacuum at the pressure regulator-fuel filter okay?also check the coolant temperature sensor/idle air control valve and throttle position sensor-
