1998 Chevy Malibu Codes
82,000 MILES • 6 CYL • FWD • AUTOMATIC
PARAMEDIC
Can somebody help me with these codes, the car is running well, but starting it have to push accelerator pedal a little
P0300
P0452
P1362
P1374
P1374pd
Feb 26, 2008 at 1:13 PM
BMRFIXIT
  • 19,053 POSTS
Here is some of what those codes mean
what I would is record all the codes and freeze frame I have reset the ECM and start over drive the car and see what pop up and go from there
or you can start with a tune up/crank sensor
P0300 Random/Multiple Cylinder Misfire Detected
P0452 Evaporative Emission Control System Pressure Sensor Low Input
P1362 No Signal In TDC1 Sensor Circuit
good luck
Feb 26, 2008 at 1:56 PM
DENNYP
  • 1,824 POSTS
sounds like you might need a crank sensor.
Feb 26, 2008 at 11:11 PM
