1997 Chevy Malibu will not start
DAN LANTZ
Electrical problem
1997 Chevy Malibu V6 Front Wheel Drive Automatic 110000 miles
car turns over, does has spark to spark plugs, has no fuel pressure. All fuses and relays are ok, but also with ingition switch in on position there is no indecator lights on dash (check engine, oil, ect...) like normally come on and then goes out when car starts
Dec 6, 2007 at 1:24 AM
BMRFIXIT
  • 19,053 POSTS
[quote:a2476f1dd4="dan lantz"]Electrical problem
car turns over, does has spark to spark plugs, has no fuel pressure. All fuses and relays are ok, but also with ingition switch in on position there is no indecator lights on dash (check engine, oil, ect...) like normally come on and then goes out when car starts[/quote:a2476f1dd4]
You have spark but no fuel pressure all fuses and relays ok
I would say fuel pump
Locate the fuel tank in the rear of the car
Try to hit the mid of the tank while a helper trying to start car may start
So it get you home or to a repair shop
Dec 6, 2007 at 10:49 AM
