1997 Chevy Malibu transmission problems
170,000 MILES • 6 CYL • FWD • AUTOMATIC
PATRICKSS
I blew a transmission line as i was driving. I was able to fix the line and drive it home after adding tranny fluid. Now that I got the car home it will not go in reverse and neutral. It drives in D only and not any of the lower gears. In park or neutral if you hit the gas the engine bogs at about 2000 rpm?
Jan 22, 2009 at 5:11 AM
DOCFIXIT
  • 18,828 POSTS
Drive clutch pack fried all stuck together hince only drive. Will need rebuild or replacement trans.
Jan 22, 2009 at 6:16 AM
