My engine will turn over or crank when I turn the key but won't catch to start. It's not flooded as there is no gasoline smell. None of my gauges are working. When I turn the key, none of the warning lights are coming on...no check engine, no seatbelts, no oil pressure, no ABS light, no digital odometer, the gauges themselves aren't going up e.g. gas gauge, but all other lights are working...interior, radio, cigarette lighter, headlights, etc. So far I have switched the relay for the fuel pump with the cooling fan to see if that worked and it didn't. I checked the oil to see if it was overfilled to see if there was gas in my oil...that didn't work. I checked fuses to see if any were blown and none were. I checked the ECM/PCM fuses/relays to see if they were the problem and so far nothing is working. Can you please give me some idea as to what is going on?
Jul 29, 2009 at 1:48 AM
