1997 Chevy Malibu Knocking
HAM3R
  • 1997 CHEVROLET MALIBU
  • 4 CYL
  • 135,000 MILES
My malibu, when I accelerate or rev the engine, makes a loud knocking noise, started yesterday 2/1/10 as a soft, quiet knocking. Today 2/2/10 it is louder. One of my coworker says its probally engine build up and my valve is knocking against my pistons. I want to make sure they are right. Thanks
Tuesday, February 2nd, 2010 AT 11:40 PM
ERNEST CLARK
  • 1,730 POSTS
Your co-worker is probably wrong. If your valve comes into contact with your piston, your engine will self destruct almost immediately and you'll hear a lot more than just a "Knocking".
If your check engine light is coming on, then start by having your computer scanned.
Your knock could be ignition timing/fuel related. It could also be mechanical, such as your oil level is low and starving your valve train/lifters of lubricant or your pistons are excessively worn and slapping against the cylinders.
There are several possible causes of a knocking sound, but they can only be properly diagnosed by a mechanic with the proper tools.
Saturday, February 6th, 2010 AT 8:23 AM
