1997 Chevy Malibu Ground g202 location
1997 CHEVROLET MALIBU
160,000 MILES • 6 CYL • FWD • AUTOMATIC
SABIMAX
  • 13 POSTS
Hi, I need to check the ground location(g202) to I can check the ground for my blower motor...What I need is the location of G202 in order to see if the ground is loose or corroded!
Nov 6, 2010 at 7:41 AM
BLUELIGHTNIN6
  • 16,542 POSTS
G202 is on the left side of the dash. the blower motor's ground is g201 though which is on the right side of the dash.. unfortunately don't have a pic but easiest way to find it is to follow the BLACK ground wire from the ashtray lamp OR the power outlet either one, the ground wire goes to the exact same spot as the blower motors ground wire.
Nov 6, 2010 at 9:34 AM
SABIMAX
  • 13 POSTS
i found it, checked out all the ground connections, all were good, still cant seem to figure out this blower motor thing. Only place i don't get voltage is from the purple wire at blower connector when I put it on High setting,,I do get voltage at resistor and get voltage at low heat settings on purple wire. My ground there is good. Fuses tested and good, Relay tested,good switched with newer one for enterntainment,,,,,,, still nothing blower is new, resistor new, and control switch is new...Still nothing, very perplexed. Any Ideas?
Nov 7, 2010 at 3:52 AM
SABIMAX
  • 13 POSTS
also, tested no continuity at purple wire, if that helps anybody!
Nov 7, 2010 at 4:00 AM
SABIMAX
  • 13 POSTS
Would anybody know which contact terminal # on relay at fuse panel box I should be checking, my wiring diagram shows the purple wire going to relay switch
Nov 7, 2010 at 4:03 AM
CALZERO
Hope you already fixed your problem. If not the fuse and relay your looking for is in the Underhood Junction box. Hi Blow is on its own curcuit check 30A fuse and Blower Motor Relay for function.
Dec 14, 2010 at 10:31 PM
