Where is the dipstick located on a 97 Malibu?
1997 CHEVROLET MALIBU
138,000 MILES • 6 CYL • 2WD • AUTOMATIC
TRENREV1
  • 7 POSTS
I can't find the dipstick to check the transmission fluid. Where is it located?
Sep 14, 2010 at 11:50 PM
WRENCHTECH
  • 20,761 POSTS
It doesn't have a dipstick
https://images.2carpros.com/forum/automotive_pictures/561653_Trans_fluid_level_screw_97_Malibu_1.gif
Inspect The fluid level should be checked when the transaxle is near room temperature or at 40 °C (104 °F) . CAUTION: Removal of the fluid level screw when the transaxle fluid is hot may cause injury. Use care to avoid contact of transaxle fluid to exhaust pipe . 1. Engine OFF. 2. Raise and suitably support the vehicle. 3. Place oil container under check plug. 4. Remove oil check plug. 5. Oil level should be at bottom of oil check hole. Because the transaxle operates correctly over a range of fluid levels, fluid may or may not drain out of the screw hole when the screw is removed.
Sep 15, 2010 at 12:47 AM
TRENREV1
  • 7 POSTS
Thank you for your detailed response.
Sep 15, 2010 at 2:00 AM
WRENCHTECH
  • 20,761 POSTS
Your welcome. Leaving feedback is appreciated.
Sep 15, 2010 at 2:05 AM
