1997 Chevy Malibu Car wants to die
90,000 MILES • 4 CYL • FWD • AUTOMATIC
CRISTINAELISABETA
Once a day when I turn my car on and drive for about 10 seconds,it wants to die.The rpm gauge will go down and it seems to want to turn off but it doesn't.It does about once a day and when I am approaching a stop sign is when it happens.Any idea what the problem might be? I don't know if this matters or not but I just changed the IAC valve.
Apr 29, 2009 at 7:17 AM
  • 75,988 POSTS
Check the EGR and PVC valves and also the transmission torque converter clutch solenoid try disconnecting it and see what happens.
Apr 29, 2009 at 11:17 PM
CRISTINAELISABETA
After I disconnect the transmission converter torque clouth solenoid,what do I do? Do I disconnect it and connect back right after I disconnect it? How can you tell if the solenoid needs to be changed? Thank you for your help.I really appreciate it.
Apr 30, 2009 at 5:26 AM
  • 75,988 POSTS
Disconnect the TCC solenoid and test drive and see whether it act up
Apr 30, 2009 at 8:48 AM
