Where is the thermostat located under the hood? I have a 1998 chevy lumina.
Apr 2, 2006 at 4:52 AM
OILPAN49
MEMBER
Open the hood and follow the upper radiator hose to a metal housing with 2 bolts on each side of the housing. Remove the upper radiator hose and anything else connected to the housing, remove the 2 bolts. The thermostat is located inside the housing. -op-
