Radio illumination gone
JAKECAREY
I have a 2002 Chevy Suburban with 92000 miles. it is the 1500. It has every option available. It is in perfect shape except all the illumination behind the buttons for the radio are out. Non of the other buttons are out just those. Could it be a fuse or something? The area where the clock is is working but none of the illumination behind the preset, volume, seek, ect...
Suggestions?
Jake Carey
Jan 18, 2007 at 3:33 PM
JDL
  • 16,098 POSTS
The illumination for the radio, brown wire is voltage, headlamp switch on. Black wire is ground. If you have good voltage and ground, then I suspect issue with radio.
Right now, I suspect you missing voltage or ground for illumination, have to check those circuits.
Mar 20, 2015 at 7:05 AM
