P/s Door Panel
LMADKINS
On my 1994 Chevy Lumina with 89000 miles and 3.1 engine The passenger door will not open. I am hoping that something has just come loose in the door. How do you get the inside door panel off to so you can look and see if a rod or something has come off.
Sep 13, 2007 at 4:35 PM
JEFFROHOTROD
  • 31 POSTS
There should be some screws along the edge of the panel and one or two screws beside the inside door handle. Once you get the screws out just pull on it and it will pop out. One its popped out unplug the wiring from the panel.
Sep 14, 2007 at 3:30 AM
