missing w/ speedometer jumping
DWARREN
97 Chev Lumina, 106K miles, 6 cyl auto. At highway speeds my car occasionally misses, sometimes so bad it shudders and the speedometer jumps up and down. One mechanic guessed oil pan gasket and manifold gasket ($1600), another suggests it may be a bad coil pack. Have you heard of these symptoms? Thanks for your expertise.
Nov 19, 2007 at 3:14 AM
  • 75,988 POSTS
When was the last major tune-up?
Does it have a check engine light On or has flashed if so you need to have the OBD2 read and comeback with the code/s.
For a start check the fuel pressure with a gauge.
Nov 19, 2007 at 4:11 AM
